Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › burning smell from dishwasher
- This topic has 18 replies, 5 voices, and was last updated 17 years, 1 month ago by
fasetester.
February 12, 2009 at 1:24 pm #43419
fasetester
Participanthi guys have to look at a hotpoint dishwasher dwf50s their is a burning smell coming from it. any known fault to look out for thanks fasetester 🙂
February 12, 2009 at 2:00 pm #277200Martin
ParticipantRe: burning smell from dishwasher
Module, motor, wall socket, heater wiring?
February 12, 2009 at 7:51 pm #277201fasetester
thanks martin for your reply. the husband said he does not think it is washing you can here a clicking sound and then the get the burning smell. possible jammed motor. if the washer pump bearing are gone . or a leaking shaft seal can any of the two be replaced thanks fasetester 🙂
February 12, 2009 at 8:39 pm #277202Lawrence
if you are getting a burning smell when it should be washing then its fairly certain the motor is knacked.
Failing that it could be element coming onFebruary 12, 2009 at 9:16 pm #277203fasetester
thanks lawrence for the reply can the bearings and shaft seal be replaced . what would cause the heater to come on a blocked pressure vessal thanks fasetester
February 12, 2009 at 10:09 pm #277204Lawrence
I am not sure with regard to the motor seal kit I am looking at the same info as you and yes a blocked pressure system would bring the element on .
February 12, 2009 at 11:13 pm #277205leavemetogetonwithit
My money’s on the R.I.F.
Mike.February 13, 2009 at 8:40 am #277206Martin
fasetester wrote:thanks lawrence for the reply can the bearings and shaft seal be replaced . what would cause the heater to come on a blocked pressure vessal thanks fasetester
The motor and circulating pump housing are sold seperately. The heater is the through type flow control therefore if the motor doesn’t work then the heater doesn’t come on.
Enough on the speculation and best you call by and check it out eh? 8)
February 13, 2009 at 11:11 am #277207fasetester
what is the rif mike fasetester
February 13, 2009 at 5:33 pm #277208fasetester
hi guys went to check it out. when trying to set program nothing would only light the 50 ligh on the left hand side. disconnected and removed base washer motor was badly rusted. and base plate motor smelt if it was
frying it was leaking down into motor said she had it over six years and would go for new dishwasher fasetester.
February 13, 2009 at 5:45 pm #277209timdowning
Cor what alot of effort for no return. :rolls:
February 13, 2009 at 11:52 pm #277210fasetester
the all dont turn out the way you want what would you do tim fasetester 🙂
February 14, 2009 at 8:08 am #277211Martin
leavemetogetonwithit wrote:My money’s on the R.I.F.
You were spot on there Mike. 😉
February 15, 2009 at 2:50 pm #277212leavemetogetonwithit
fasetester wrote:what is the rif mike fasetester
http://connections.connect-distribution … uery=dwf50
When you smell burning, it’s one of the first places to look.
Mike.February 15, 2009 at 11:11 pm #277213fasetester
at the washer pump mike fasetester 😕
