‘Burnt’ components in Britannia range oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum ‘Burnt’ components in Britannia range oven
  • #82861
    scotland
    The lower element in our Britannia range has failed so I pulled the oven away from the wall to investigate how it is removed.
    Upon removing the back panel I encountered some burnt looking components (the light fitting is particularly bad) and fibrous material. I’ve included a picture.
    Should this be cause for concern?
    #421005
    lee8
    Re: ‘Burnt’ components in Britannia range oven
    No its grease from the cooking process. Oven are made with materials that do not burn at temperature that the cooker could produce, even if components failed the element will destroy itself before.
    #421006
    scotland
    Thanks for your reply.
