Burnt out microwave
  • #50267
    mrsteve
    Does anyone know how a microwave could end up like this? It’s from where I work- under the mica sheet the metal casing has slightly burned away like a crap welding job. Here’s a pic…
    I’ve not seen this happen before- does anyone know what might have caused- splatters not wiped off or is it some major failure. It’s only a year or 2 old.
    Cheers
    #304218
    Washman
    Re: Burnt out microwave
    Usually caused by appliance not being cleaned properly , and crud building up around wave guide.
    Washman
    #304219
    chezza
    Given the ” condition ” of the rest of the cavity, I think it is likely to be due to splashed food, which will continue to cook every time you reheat your coffee etc…anything with a high fat content ( cheese, butter etc etc ) will be worse than other bits but all will eventually do this
    #304220
    mrsteve
    Thanks for the replies.
    Is it better to stop using the microwave though?
    #304221
    Washman
    Yes do not use until checked out by microwave engineer.
    Washman
