Bush 3kg vented drier TD3CNBW
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bush 3kg vented drier TD3CNBW
  • #100693
    andyjawa
    Just a bit of a general helpful comment. When these cheap Chinese made tumble dryers are “dead” i.e. will not work, so does nothing what so ever, first check the drum`s internal rear filter for a major blockage because someone has neglected to clean it. What happens is there is a small rectangular reset button ( that resets an overload stat ) that has to be reset and that is located at the front of the machine at 6o/clock position below the door behind the detatchable heater air intake plastic filter. So you clean the drum filter, reset this over load stat by clicking it upwards, clean this heater air intake filter and the machine should, all being well elsewhere, start to work. Those of you who are familiar with White knight efforts know about the external red reset button on the back of the machine that will just stop the heater from working. With this Bush the reset button stops the whole of the machine from working. If you find the Bush user manual it tells you what you need to do…that if of course if the manual has not been lost… hence this post.
    #481785
    this may help
    andyjawa
    Yes thanks very much. Despite the label missing by the side of the offending reset switch and the manual typically being mispIaced I managed to suss the damn thing. More down to sheer luck.
    #481787
    does seem a weird place for an overheat sw
