bush a126q leaking
  • #88581
    jon90
    Hi, have been out today to bush a126q leaking from dispenser draw trickling down outside corner of cabinet, have cleaned out dispenser, draw and jets but still leaking, is this a common fault with these machines is there a modified dispenser housing /draw available to cure problem as can’t figure out where its coming from, any help greatly appreciated . regards Jon.
    #438644
    johnnyj
    Re: bush a126q leaking
    Changed a few dispenser tops for that usually one of the first things that pop when searching for parts.
    #438645
    PaulG
    You could try blocking off the jet holes closest to the front with some mastic. It’s worked for me in the past. Even if only a temporary repair while a new dispenser arrives.
