bush a126qb
  • #89119
    robbo1973
    hi been to this one today for a letting agent and buttons pushed through which ive had before so refit and now when you press start the door doesnt lock and the 3 lights flash very fast maybe 10 times but far too quick to count and nothing,any one had this before?
    #440397
    codlets
    Re: bush a126qb
    Had one the other day, however only the start light was flashing rapidly, new door lock solved it
    #440398
    jimca007
    Re: bush a126qb
    Does that if one of the wires from the motor plug into the taco/stator or brushes is broken. Surprisingly this is a common fault the biggest culprits are the taco wires or the white wire going to the thermal fuse although the black brush wire sometimes breaks too .
    just as an afterthought I have had customers accidently activate the child lock messing about with buttons trying to get the machine to start , might be worth a check first.
