Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bush a127qb
- This topic has 5 replies, 3 voices, and was last updated 10 years ago by
Rockintrick.
March 10, 2016 at 11:00 pm #87836
Rockintrick
ParticipantHi. Very new to forum. Can someone tell me how to find out my error code and where I can read what it means. Thanks
March 11, 2016 at 9:59 am #436142iadom
ModeratorRe: Bush a127qb
THESE are the only ones we have but these are for the Turkish made machines.
Yours might be one of the Chinese models. 🙁
March 11, 2016 at 10:21 am #436143Rockintrick
ParticipantRe: Bush a127qb
How do I get the error code to show up so I can see what code it may be? I personally think it needs a new pcb but I only guess it’s this as my wife said she heard a pop noise and now the start/pause but just constantly flashes. It won’t run any of the programs. So could I be correct?
March 11, 2016 at 10:59 am #436144iadom
Hopefully someone who repairs these may know, there isn’t a barge pole long enough for me to go anywhere near one.
March 11, 2016 at 5:55 pm #4361451totalshambles
Most Bush are Turkish if your serial number is very long and begins with 0065 it`ll be Turkish.Yes I thing your correct, does sound like pcb has failed. Question is why? You`ll have to visually look at the pcb to see if anything blown and if a track has it`ll be a pretty good indication that another component caused it which you`ll have to also suss before you go and buy a new pcb- look for armature fault, suppressor blown, door interlock short. Charles Hyde and son near York do a great many Bush spares including pcboards phone them up armed with all the info you can gleen, model, serial, pcb numbers. Most Bush pcb are circ 70 quid though some are as low as 30 quid. Ebay might also be another bet but make sure the pcb numbers are the same because many of these boards look the same but are not. Partmaster Connect is your last resort as those guys are expensive. Bit of bad luck isn`t it? Still on the bright side at least it isn`t a Miele or a Bosch, Hotpoint out of warranty- and yes they go wrong too and big time with it..
March 12, 2016 at 6:58 am #4361461totalshambles
To add. If you go on Ebayuk washing machine spares and type in Vestel you also get a whole host of parts come up.
The pcboards usually start with 207………and can be inexpensive so all is not lost.
