Bush A127QW – Intermittent Problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bush A127QW – Intermittent Problem
  • #83150
    Bunta
    I have an issue where the washing does not spin… i looked underneath the washer and a white clip had a small portion snapped off – i took the clip off and put it back on and the washer worked. Then the next time it didn’t. So i did the same procedure as above and it worked. i have done this about 10 times. now it doesn’t work at all with regards to spinning. It fills up with water fine, it drains fine. See picture attached. Any help would be greatly appreciated in my pocket with Christmas coming soon. helppppppppp
    #421882
    nigegt
    Re: Bush A127QW – Intermittent Problem
    Most likely the motor brushes are worn out.
    Nige
    #421883
    Bunta
    Thanks for the reply – we have only had the washer 14 months. what are the components called i have highlighted in the picture?
    Many thanks in advance
    #421884
    nigegt
    The one highlighted yellow is one of the motor brushes. You’ve been lucky to get 14 months out of a Bush washer. Such a quality product. 😀
    Nige
    #421885
    Bunta
    i know… bad buy. Could i change the brushes myself? Where can i get the parts?
    Thanks Again
