Hey 😀
I have a Bush AE56DW cooker that’s around 2-3 years old. I noticed though yesterday that my main bottom fan oven is not working, i can turn the fan on but when i turn the temp nob the thermostat light does not come on, the oven does not heat up and i’m pretty sure there was a light on in the oven also which now does not come on.
After a bit of research i thought maybe the element had gone but would this also explain the thermostat and oven lights not working? The top oven still works fine and thermostat light is working on that, grill is fine and the top electric rings are all working ok.
I have also read about the oven function selector switch but i’m unsure to be honest. This cooker has one nob for turning the fan function on, ie fan and oven, just fan no heat and then just heat no fan i think the other option is. The heat is then turned on via another nob and that’s usually when the thermostat light comes on until its up to temp.
I’m thinking the oven function selector switch may be used for choosing the fan options as i’m thinking that’s the “function” bit and if so as i say the fans are working fine.
Has anyone got any advice? I’m on a tight budget so if there is possibly someway i can test to find out whats gone on it before i buy a part this would be great.
Thanks in advance.
