Our cooker is no longer working. The hob works fine.
Our cooker has a duel oven/grill. We rarely use the grill but happened to use it today. We then went to use the cooker after and now it won’t qork. I suspect the grill has damaged the element?
I believe it is a duel oven/grill element. The little light next to the knob also doesn’t light up now. Would this also be because the element doesn’t work or could it be a different, bigger issue? This is what I’m concerned about. We don’t have a lot of money and can not afford to replace the element if it isn’t this. We certainly can’t afford a new cooker at Christmas
We had trouble turning the knob but this seems ok now. Should I take the plunge with the element?
Thank you,
James.
