Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Bush AE66DCA main oven fault – help please
- This topic has 4 replies, 4 voices, and was last updated 11 years, 10 months ago by
petgeobar.
May 20, 2014 at 3:19 pm #80746
petgeobar
ParticipantYes, we bought one in a moment of pecuniary necessity, and now less than 18 months on the main oven has ceased working. When you switch the main oven on the fan runs. The panel light does not come on, nor does the interior light (tests ok). Both elements test ok (continuous) as does the thermal cut out. The other oven and hotplates are fine.
I assume the next possible suspects are the main oven control switch behind the knob panel, or possibly the thermostat, though I have always thought that thermostat failure usually resulted in overheating rather than total failure. Any help and suggestions (other than the obvious one!) will be greatly appreciated.
Pete
May 20, 2014 at 6:38 pm #414016Jackal
ParticipantRe: Bush AE66DCA main oven fault – help please
Pete hi
If the elements are fine then it suggests the selector switch is likely to be the cause of the issue.
It is possible the stat could be at fault although when this fails on this model it either overheats as you say or it only hears a little, usually upto around 50 degrees.
Your problem is going to be getting hold of the spares as Argos/Homebase do not supply spares for out of warranty appliances.
Part number for the selector switch is 32001426
Part number for the stat is 32013060
Sent from my iPhone using Tapatalk 2
September 10, 2014 at 12:06 pm #414017duvlin
I have the same problem and wondered if you manage to sort this out at all.
February 17, 2015 at 12:03 pm #414018fergy9271
Hi i have the same fault on my bush AE66DCA oven and been qouted £25 for the main control switch however the main control still works as the fan turns on so i have been looking for main oven control switch and found a company called dhs who supply the parts and main control is £6 and the oven control is £10 all i need now is someone to tell me how to fit it thanks
February 17, 2015 at 3:39 pm #414019fergy9271
Chsinteractive for switches etc for bush cookers cheap manufacturer
