Bush BCLU100DFB Range
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Bush BCLU100DFB Range
  • #99551
    mick mcgregor
    I have been asked to look at a Bush dual fuel range the problem is the 8 burners,right side four all ignite and stay lit on release but the left side four ignite but don’t stay lit on release.
    I have checked all contacts and found none loose or dirty and no sign of over heated or burned wires although i havent checked circuit with a multi meter as i did not have it with me.
    Any ideas?
    Thanks!
    #476850
    That looks to be a Termikel made one so, pretty much, there’s no support for them.
    Sounds like a thermocouple problem though.
    mick mcgregor
    kwatt wrote:That looks to be a Termikel made one so, pretty much, there’s no support for them.
    Yes but for all four to stop points to an electrical feed problem or first inline switch problem maybe ?
    Thank you for your reply!
    #476852
    No idea as there’s no info on them available to me at all. 🙁
    kaibart
    As the top is gas you will need a gas safe engineer to inspect or change any part, only thing I can tell you is to pull a control know off 1 that isn’t staying light and try lightning it with control know off
    #476854
    mick mcgregor
    kaibart wrote:As the top is gas you will need a gas safe engineer to inspect or change any part, only thing I can tell you is to pull a control know off 1 that isn’t staying light and try lightning it with control know off
    I used to work for Flaval Leisure building gas fires and cookers, safety first!
    #476855
    does sound odd though
    most gas cookers have seperate thermo couples for each burner so the chance of all 4 going at once is very low indeed. Unless they failed one by one over time and they have not said so
    i would try the knob off trick. may be mechanical stopping the knob going in far enough to hit the lock point
