Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bush BFSNB12W – F5 Error
- This topic has 11 replies, 2 voices, and was last updated 2 years, 8 months ago by
mikedmc16.
August 1, 2023 at 10:26 am #102143
mikedmc16
ParticipantHi,
I have a Bush BFSNB12W dishwasher that is giving up the F5 error.
I’ve googled and youtubed to my hearts content. It seems to be either a draining issue or a insufficient intake issue.
The machine drains, and fills up but 2 minutes in after it drains water away the F5 error springs up. It seems when it is supposed to fill up again.
I have undone all pipes and checked, water is flowing through the pipes to the machine fine and also draining away fine.
As it is filling and draining in the first couple of minutes, and not intermittent I am at a loss but it has lead me to the inlet valve?
Is this the most likely possibility? Anything else I could look at first?
Thank you.
August 1, 2023 at 8:31 pm #487707electrofix
Moderatorsomewhere there is a pressure switch
this senses water level. its either blocked up ( dont blow into switch directly)
or there is no water going in to sense
check for water flow, check switch and make sure its not blocked. check wiring from switch to board
or the board is faultyDave
August 2, 2023 at 7:27 am #487708mikedmc16
Participantelectrofix wrote: somewhere there is a pressure switch
I will find it today and check, thank you.
How can I check switch is working, once I’ve confirmed water flow and not blocked?
August 2, 2023 at 8:12 am #487709electrofix
Moderatorno easy way. with the later switches you can destroy them if you blow into it so the only way is to swop them out
your lucky in one respect as this unit is a known manufacturer , most Bush stuff is chinese junk with little access to spares or information
DaveAugust 2, 2023 at 9:24 am #487710mikedmc16
Participantelectrofix wrote:no easy way. with the later switches you can destroy them if you blow into it so the only way is to swop them out
DaveOk. So if water flow and not blocked, best to simply change the switch. If that doesn’t work it’s the board and time to simply get a new dishwasher.
August 2, 2023 at 8:05 pm #487711electrofix
ver likely
the pressure is fed to the swich via an air chamber, make sure thats not blocked
if you get me the long serial number will try to find correct switch
August 2, 2023 at 10:49 pm #487712mikedmc16
ver likely
This I assume is the SN but entering into Google gets no response.
August 2, 2023 at 10:55 pm #487713electrofix
Moderatorgoogle wont but that serial narrows it down to one machine
cant read it from the pic
August 3, 2023 at 7:29 am #487714mikedmc16
Participantelectrofix wrote: google wont but that serial narrows it down to one machine
It’s 01712114002312550032
August 3, 2023 at 8:50 am #487715electrofix
Moderatorok now i have the correct machine
your has got a flow meter that measures water coming in
check wiring to this ( have had mice eat the cables)
if wiring ok it should be either this part or the board
cant promise i am right as you can imagine but changed lots of flow meters
https://shop.ukwhitegoods.co.uk/42153776-dishwasher-air-break-flow-meter
August 3, 2023 at 9:48 am #487716mikedmc16
Participantelectrofix wrote:ok now i have the correct machine
Will check it once home today.
Out of curiosity, as you know your Dishwashers and these Bush are full of chinese junk, what is a recommended Dishwasher make / model?
August 3, 2023 at 8:37 pm #487717electrofix
Moderatormost appliances contain chinese components
you dishwasher is made by a turkish manufacturer called Vestel
