Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bush CTFS60DBLECB Shop Mode
- This topic has 10 replies, 4 voices, and was last updated 3 months, 2 weeks ago by
macmini.
December 21, 2025 at 4:35 pm #103724
macmini
ParticipantHi guys
Message from a customer just before Christmas to say they’ve got their CTFS60DBLECB stuck in shop mode.
Does anyone know the reset procedure?
December 21, 2025 at 5:01 pm #494335electrofix
Moderatorwell its Vestel built. service info is on ASWO
does not mention a demo mode. does mention a key lock but does not seem to say how to take it on and off
but
there are over 15 models with the same model no, would need the serial no to look it up to see if the correct one differs in any wayalso cant see this having a demo mode as there would have to be full electronic control for the hob and this uses regulators
have they tried turning it off for 10 mins and then reset clock when they turn it on ?
December 21, 2025 at 5:41 pm #494336don
ModeratorThis cooker has a 3 button timer, there is an option of “dur” in the instructions on pages 25 and 26 which relates to cooking timer on and duration I’m guessing it is in this mode. There isn’t anything else I can find which relates to demo.
Link for instructions https://documents.4rgos.it/v1/static/4496713_R_D001 Gives you a start anyway.
Don
December 22, 2025 at 9:29 am #494337macmini
ParticipantSpoken to the customer, definitely displaying “SHOP” on the display – hob still works.
Asked for the serial number but not forthcoming. Obviously, the Bush/Argos helpline has been a waste of time.
December 22, 2025 at 10:05 am #494338electrofix
Moderatorsounds a bit odd
can understand shop mode but shop mode where you can still turn on the hob makes no sense at allchange the timer it will probably be ok as i cant see any other components causing it (£20 on ASWO)
or bridge the timer relay
December 22, 2025 at 10:11 am #494339macmini
ParticipantCheers Dave, obviously she’s wanting it sorting for Christmas and I’m away at the moment.
Seems like it’s a standard Vestel timer used on their integrated ovens. Looks to be the same as Servis branded, just this time free standing. No procedure in their service manual either!
December 22, 2025 at 10:14 am #494340electrofix
Moderatoras said previously has she tried turning off , waiting and then set time ?
some shop mode get cancelled after power turned off
December 22, 2025 at 10:55 am #494341macmini
Participantelectrofix wrote: as said previously has she tried turning off , waiting and then set time ?
Yeah she’s tried that. Tried the various fixes I’ve sent too.
New timer it is, but I suspect she’ll try and get a new cooker delivered tomorrow in time for Christmas.
December 22, 2025 at 12:57 pm #494342electrofix
Moderatorand probably buy another Bush
people dont learn
if you were not away you could have bridged it. Most people dont use the timer anyway
December 22, 2025 at 1:36 pm #494343macmini
ParticipantMore than likely, unfortunately.
…and have the same experience in another couple of years!
December 22, 2025 at 9:20 pm #494344Hollytree_Technical
ParticipantI don’t know if this is the correct set of instructions but google suggests that you should try the following:
Turn off at wall
Wait 10 seconds
Turn on at wall
Within 1 minute of power on press both the “Mode” and “-” buttons together for 5 secondsJem
