Bush Dishwasher – WQP12-9348 Error E1
Home Forums Public Support Forums General Enquiries And Questions Bush Dishwasher – WQP12-9348 Error E1
  • #91674
    Damon1801
    Hoping for some advice please.
    I have Bush dishwasher that is coming up with E1 error code around 5mins after starting a program. According to a similar manual this is related to the inlet water flow being too low and is not taking enough water which should be around 3ltrs in 4mins (45cm model) according to manual.
    The inlet valve is clear and working fine. The inlet flow looks adequate and the flow meter is moving ok.
    I’m now a bit stuck and wondered if there is anything else I can check.
    Thanks in advance for any help.
    Damon.
    #448940
    thekeymurphy
    Re: Bush Dishwasher – WQP12-9348 Error E1
    What’s the water pressure like?
    #448941
    Damon1801
    It’s connected very close to the mains water. When I tested the flow through the inlet valve it looked more than adequate although I didn’t measure it….
    #448942
    thekeymurphy
    Measure it just to make sure. If everything is ok, I’ll have a think of what else it could be.
