Bush DWFS 126 salt problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bush DWFS 126 salt problem
  • #83200
    Neil684
    Hey guys,
    I installed a new Bush DWFS 126 yesterday, it seems to be working fine apart from leaving a white powdery deposit on everything. I assumed this is salt? I have trawled the internet and the manual to see if I can find a solution to the problem but with no luck.
    The supplier says they will send an engineer out but not for a week, I have a party this weekend so was hoping to try and sort it myself.
    Help and advise needed please.
    Neil
    #422023
    Re: Bush DWFS 126 salt problem
    Does the White deposit taste of salt? Have you overfilled the salt container and not secured the cap?
    #422024
    Neil684
    Thanks for the reply Martin,
    I hadn’t thought of tasting it, now I have I wouldn’t say it was a strong salty taste but slight. Yes the lid is secure and although full It is not over full with salt (about an inch from the top)
    #422025
    Do another maximum wash cycle without dishes in the hope of clearing the problem. Otherwise there is a problem with the salt regeneration process I would think. Though a sudden report of white salty deposits is almost always associated to a salt cap, salt cap threads cracked or salt lid gasket failure.
    #422026
    Neil684
    I have cleaned the threads, checked the gasket, screwed cap on tight and put it onto a full cycle. Fingers crossed 🙂
    #422027
    Neil684
    The outcome was the same, so I guess I need to wait for an engineer.
    Thanks for your help, its much appreciated.
    #422028
    ……one further thought, I hope it was salt you poured into the salt reservoir and not loose detergent?
