Hi my machine flooded from the base and the E4 error code came on. I emptied the water and tipped the machine backwards as suggested at a 45 deg angle to clear the code. This worked but machine still flooding from the base and now tripping the power.
I’ve spoken to Bush they think it might be a blocked water inlet valve. Hence the E4 error code it flooded then tripped the flood switch. Cleared it but flooded again tripping the power. So inlet valve needs taking off and descaling. Fingers crossed they are right.
