The fridge part oif my Bush fridge freezer, model no BSFF60C is not working. As advised by technician I emptied it, cleaned it and left it to defrost for 48 hours. Unfortunately nothing changed and it remains not working.
I searched the internet and surmised that the Evaporator Fan Motor could be at fault. However, I can not see where the evaporator fan is located. Can you advise? The model number for the fan I believe is Bush Evaporator Fan Motor Myl 25mm. If required are you able to supply this fan?
Regards
