Bush Fridge Freezer Fault
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bush Fridge Freezer Fault
  • #97105
    stevem72
    I have a bush fridge freezer. It has been working perfectly. Over the weekend I de frosted and cleaned it but now it won’t work.
    power is going to it. Light in fridge is workin. It’s getting warm round back at bottom .
    It seems to make a click noise but just doesn’t fire back up!
    Any suggestions would be appreciated
    #466156
    Sounds like a seized compressor, if you leave it a few minutes does it click more than once?
    #466157
    stevem72
    Hi. Yes. It will click. Pause a bit then click again. Best way i can describe is its trying to fire up but not quite happening. If that makes sense
    #466158
    99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain the compressor has seized, a costly repair even on a decent quality machine, a definite no no on a Bush.:(
