Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bush HW60-1460D – sudden motor speed change – Err 7
- This topic has 6 replies, 5 voices, and was last updated 14 years ago by
Hollytree_Technical.
March 30, 2012 at 10:01 pm #68721
Hollytree_Technical
ParticipantHi All
Got called to this machine because it is throwing up Error 7 on a fairly regular basis (apparently it has done it on and off for a while but is now much more regular), According to the fault codes Error 7 is a motor error. What appears to happen on any cycle is that the machine will get to the point where it starts to tumble and after a random amount of time (10 seconds to 2 minutes) it will suddenly kick up in speed for about 2 seconds before shutting of the motor and trying again after which it gives up and throws up the error.
I have checked:
Insulation – c275Mohm
Wiring Loom to motor
Motor and tacho windings
Brushes (Plenty left and not stuck)
Magnet
Visual check of board
Water level
Fill valves
Heater
NTC
BearingsI am having to assume that it is the board either not sensing or failing to control the motor properly but wondered whether any else had come across this fault or had any other ideas.
If it is board then does any one know what the part number is please as connect don’t have this machine listed.
Serial No:CE0JC4E0H00CRA6K0927
According to the customer it is an Argos machine which only just over a year old.
Thank you in advance
Jem
March 31, 2012 at 6:26 am #372563tj5793
ParticipantBush HW60-1460D – sudden motor speed change – Err 7
Sorry I don’t know the part no but that model nos looks very much like a Haier model nos. is the machine made in the PRC?
March 31, 2012 at 9:35 am #372564Hollytree_Technical
ParticipantRe: Bush HW60-1460D – sudden motor speed change – Err 7
PRC?
It does say Haier on the motor if that helps.
Jem
April 1, 2012 at 7:47 pm #372565leavemetogetonwithit
Hollytree_Technical wrote:PRC?
“People’s Republic of” China.
Mike.April 1, 2012 at 8:25 pm #372566stevebunyan
Just PMed you.
Sent from Steves
iPhone using TapatalkApril 2, 2012 at 6:13 am #372567spimps
Wires from motor socket to tacho are worth a tug!
April 2, 2012 at 4:57 pm #372568Hollytree_Technical
I think I tugged them all and they all seemed firm.
Jem
