bush ae6bfs built in oven
Fan works but no heat and no neon lights indicating power or thermostat
Is this an element problem? Checked for continuity elements seem ok but flat batteries on my insulation tester thwarted my attempts. Selector switch looks ok and stat sounds ok, any suggestion most appreciated.
Thanks Darren
Thermostat or TOC. Pull the wires off the stat and hook them together – switch oven on and see if it heats. Stat is only an on off switch so this is the quickest way to check the rest of the oven works OK. Could be TOC but I would think that would inhibit the whole oven from functioning.
My money’s on the stat as the temperature light isn’t on – therefore power is probably getting to the stat from the selector switch and not being switched through the stat.
