Bush oven fan not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Bush oven fan not working
  • #100337
    shrimp
    I have a Bush DHBDBL60W and the fan is not working so I tested for resistance on the oven limit thermostat / thermal cut out (Sorry I don’t know what the correct part is called) and I got resistance and the reading was 0.000 k ohms so I tested the fan motor and I’m getting 0.142 k ohms so would anyone know what could be wrong.
    #480213
    if it has a clock that’s the first thing to look at
    after that its the selector switch most likely
    Also Bush is an argos own brand and spares are a bit of a nightmare
    shrimp
    electrofix wrote:if it has a clock that’s the first thing to look at
    No it doesn’t have a clock. Would it be the selector switch if the oven heats up.
    #480215
    could be fan motor or switch
    shrimp
    I bought a new fan motor but the seller sent me a 21 watts so can I still use it if my old fan motor is 26 watts.
    #480217
    no problems
    as long as it fits it will be fine
    shrimp
    electrofix wrote:no problems
    I contacted espares about it being different and they said send it back.
    The new fan motor looks the same as the old one but the new one says P/N 32013533, Bekatech YJ61-16a HZ02 21W and my old motor says P/N 32013533, Hunan Keli.
    #480219
    shrimp
    electrofix wrote:yes i get that
    https://shop.ukwhitegoods.co.uk/32013533-genuine-fan-oven-motor#product_more_info.tab
    listed as 23W
    I know what you mean from a previous comment that bush parts are a nightmare so I might end up getting a new cooker.
    It’s listed as 23W but if the box says VST32013533 or FM0305 it will have a 21W part inside. Would you know if there’s anyway of finding out if they changed the motors to 21W.
    #480221
    just fit it as long as it fite mechanically
    its only a fan motor so it should be fine and 2w it neither here or there
