I have a Bush oven model AE6BFS. It is receiving power from the mains, when switched on the fan activates but the internal light does not and the oven does not heat up, the power indicator light and temperature indicator light do not activate either. I have already changed the element and thermostat, this has had no effect. I’m now out of ideas about what the fault could be. Does anyone have any suggestions about the next steps?
Thanks for the reply, I have been leaning towards that myself but my hesitation is because the fan still comes on when the selector switch is used. Would the selector switch still activate the fan but not the heating elements if it was defective? I imagine if it was broken it wouldn’t select anything? I have ordered the part anyway and will see how it goes.
