Hi, we have a range cooker bclu100dfb we bought about 3 years ago, have now broken the glass on one of the panes that is a void in one side (similar to the size of the top oven 50cm x 21cm
Just wondering if a replacement exists either genuine or another make that would fit
Hi Don,
Its the solid door on the bottom right hand side that’s broken, the top left is the top oven, I don’t think it actually serves any purpose apart from storage possibly, but its like a proving area I’d guess in some range cookers. It does pull down like the top oven does, possibly the top oven outer glass would be a fit for it if needed
Right then, the door position no. 221 isn’t even listed on the spares document. Position 31 on top drawing has part number 32839-BL which is not available anywhere. You could try ringing Bush spares on 01759 487838 to see if you can get anywhere.
Failing that if the two doors in question are exactly the same size I would visit my local glazing company with the measurements and make the door up yourself. You may have to wait though until lockdown eases 😉
