Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Bush vented tumbler dryer won’t work in garage
- This topic has 6 replies, 5 voices, and was last updated 11 years, 3 months ago by
Saphire.
December 14, 2014 at 12:09 pm #83405
Saphire
Participantbrand new bush vented tumbler dryer won’t work in garage is this to do with a sensor that says it’s too cold ? Is there anything that can be done so that it works we have no room inside for it. Thanks
December 14, 2014 at 12:15 pm #422676kwatt
KeymasterRe: Bush vented tumbler dryer won’t work in garage
No, if it’s too cold then most modern dryers will not work and, most other appliances will also not work either.
Self condensing dryers are more prone to this but it can happen on modern vented dryers also and there is no solution other than to site it in a suitable location I’m afraid.
More on dryers specifically here:
http://www.ukwhitegoods.co.uk/help/buyi … ments.html
Typically you get these sorts of sensor errors, poor drying or rust forming on the cabinet as well as other issues.
December 14, 2014 at 12:21 pm #422677Saphire
ParticipantRe: Bush vented tumbler dryer won’t work in garage
Are there any tumbler dryers that are not so temperature sensitive is the sensor for the temperature inside the machine
December 14, 2014 at 12:23 pm #422678kwatt
Probably but it wouldn’t help with the other issues.
December 14, 2014 at 1:30 pm #422679Martin
Saphire wrote:Are there any tumbler dryers that are not so temperature sensitive is the sensor for the temperature inside the machine
Ditto all my colleague has said. The article link he provided gives you all the information you need to realise when placing a dryer in an unheated environment, like a shed, outbuilding or garage.
We cannot emphasise the point more strongly about the dangers of operating electrical appliance in places where the ambient temperature falls to 6 degrees C (the dewpoint) or below.
Enough said on that and to answer your question then (for example) the White Knight 42AW has a bi-metal thermostat (as opposed to a NTC) and therefore will still operate under these conditions.
December 14, 2014 at 1:59 pm #422680lee8
Yet there are hundreds if not thousands all around the country in garages. I would also not recommend it, l also wouldn’t recommend driving above the speed limit.
December 14, 2014 at 4:41 pm #422681Andy jones
My normal response to someone that puts appliances in a damp environment is would you put you’re PC or tv there, almost always the answer is “oh I hadn’t looked at it like that”.
