Bush washing machine WMNSN612W temperature
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bush washing machine WMNSN612W temperature
  • #93315
    mambo5
    The washing machine itself is working fine.
    Can anyone advise how can I adjust the washing water temperature that I wanted?
    I tried to follow the instruction from the user manual – select the washing water temperature by pressing the ‘temperature adjustment button’, I can see my selected temperature appeared on the led display panel (for 3 seconds), but after 3 seconds the led then jump back to the top and blinking at the top of the display (beside 60C).
    #453911
    Re: Bush washing machine WMNSN612W temperature
    not sure what you are trying to do but
    all programmes have set temperatures. you can lower the temp but not raise it
    mambo5
    I found the solution. Thanks anyway.
    #453913
    InSearchOfAnAnswer
    Hi, I realise this is a question posted from the beginning of the year but I am having a similar problem, this is the second time I have used our machine and I just set it on 60 the first time. Please can you say what solution you found?
    #453914
    InSearchOfAnAnswer
    mambo5 wrote:Re: Bush washing machine WMNSN612W temperature
    Please can you expand on the solution? And have you had any issues since with the machine?
    #453915
    would you like to describe your problem
    the member who originally posted this may not realise he has been asked a question. since a major forum upgrade the email system of letting members know that their thread has got a reply did not roll over correctly to the new format
    Also Bush is now a totally Argos owned brand name. Argos then imports low grade machines that have been badged Bush. These machines can be difficult to get parts for and have a higher than average failure rate in our opinion
