Hi All
A couple of quick (hopefully) questions concerning the above washer dryer:
1. The customer is complaining of a musty/dank smell on clothing after it has been dried within the machine – I have already checked the drain pump (drains quickly and quietly) and the waste empties into a standpipe.
2. The door seal is perished around the point where the dryer connects and will need replacing (very brown and brittle), looking at it it looks like the airflow into the machine is possibly slightly constricted which may be the cause of the seals failure – I notice that the tub has 2 spring mounting positions on it about 15mm apart, it is currently hung from the rear position – is this correct and is it likely to cause any problems if I was to move them to the front position to try and un-restrict the airflow a bit.
3. What temperature would you expect the dryer to get to within the drum? Hopefully not an issue but information that I may need when I go back.
Thank you
Jem
