Bush WM1470TV not draining.
Viewing 1 post (of 1 total)
  • #67825
    Twoten
    I have an intermittent fault with the above machine where it occasionally fails to drain.
    The machine is only just over a year old so i is unlikely to be the pump (although I can’t rule it out) but what I have found is the sump hose appears to have quite a kink in it adjacent to the pressure chamber tube. It looks possible that when this machine has a large load in it, it’s possible the tub might drop enough to increase the kink a sto the flow of water to the drain pump.
    Has anybody else come across this on one of these machines?
    Thanks,
    Keith.
