Hi we have a Bush WV12-75DW machine approximately 3 years old and it has started leaking from underneath on the left hand side during the rinse phase.
This started the day that we returned from a 10 day holiday, so the suspicion is that the float has become stuck. The trouble is I have no idea how to get to the float – as it’s a Bush model from Argos there is very little information about online.
I can’t even tip it up to look underneath as water comes gushing out then as well.
Any advice gratefully received.
Thanks.
It could be almost anything, without getting inside and seeing what the score is and what’s leaking, there’s really not much anyone will be able to tell you.
If there is a float in them, it’s used to detect a leak and halt the machine. It won’t cause it to overfill or to leak if faulty.
