Butler (smeg) dishwasher BDW7045 uphose required
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Butler (smeg) dishwasher BDW7045 uphose required
  • #65384
    boselecta
    I am trouble with the part number for the uphose (rinsing hose)that feeds the top spray arm for this Butler Smeg clone.
    thanks
    #360307
    Re: Butler (smeg) dishwasher BDW7045 uphose required
    wouldnt know but help us out, is it a 45cm or 60cm? rough age? exposed heater or tube type underneath? Solid base with float underneath or just a piece of plastic “cardboard” with no float?
    #360308
    boselecta
    hi eastlmark,
    45cm, 5 years old approx, tubular heater, plastic base with anti-flood device, hope that helps.
    #360309
    if it has the off centre lower spray arm position, then I would suggest:
    758972416 for the plastic tube
    758972415 for the hose at the bottom
    If fact, it looks like all the tubular heater models use this combo. Knowing smeg though there will be some different versions around so dont hold me to it!
    #360310
    boselecta
    Hi Mark,
    Yes it does have the double bottom off centre spray arm.
    758972415 seems to be a spray arm but I am going to try the uphose 758972416.
    Thanks alot
    #360311
    758972415 is a hose, believe me!
    #360312
    boselecta
    hi mark,
    wasn’t too confident when i went to the job, but 758972416 was exactly the part.
    Seems you know your smeg appliances!,
    so thanks again.
