Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › buy or repair, is it worth it !
- This topic has 4 replies, 3 voices, and was last updated 15 years, 1 month ago by
wellsm122.
February 15, 2011 at 1:10 am #61051
wellsm122
ParticipantHi, asking for your thoughts on a repair of a Bosch srs43c22gb classixx slimline dishwasher.
looks like the heating element is faulty, open circuit when tested.
Is it worth repairing or should I buy new.
guess part would be around £100 and it looks a bit of job to change.
any thoughts, suggestions or tips welcome
cheers ❓ :hmm:February 15, 2011 at 9:47 pm #344689CJAPeterborough
ParticipantRe: buy or repair, is it worth it !
Bosch list part number 491756 or 483257 and this will cost over £100
The heater assembly is common to quite a number of Bosch/Siemens/Neff
models.You can however source the part relatively cheaply on Ebay or other used parts outlets.
The job requires removal of the base imho although it can be done by dropping the base
slightly and then appropriate keyhole surgery,leaving the main circulation pump in place.You should firstly check the condition of the main circulation pump as this is a weak point
on the machine with a tendancy to leak and damage the bearings etcIf you have any sign of leakage under the main circulation pump then it
may not be worth doing as the machine is likely to fail again fairly quickly.February 15, 2011 at 11:35 pm #344690wellsm122
thanks Peter for your reply
interestingly I had to tip out some water from the base
a couple of months ago
although no problems since thenFebruary 26, 2011 at 9:50 pm #344691keithwilliams
i assume that when you tested the heater, that you tested between the actual heater tags. the reason i ask is that there is an inline pressure switch which will be open circuit while machine is not spraying. also the switch itself may be faulty.
i have repaired countless faults on these machines over the years and have only ONCE had one with an open circuit heater element.February 27, 2011 at 12:58 am #344692wellsm122
thanks for the update, tested with tabs removed from heater element
have ordered part await delivery, will update once fitted.
any tips on replacing, as looks like you have to do a complete strip down ! -
