BWD129
  • #39231
    timdowning
    Will the Version 3 heater box. part number 1605710 be suitable for this machine??
    Seen this model before but can’t picture if the dryer is the same as the WD440 etc.
    Cheers.
    #261737
    helo_75
    no, the bdw has a metal tank, and is therefore different than the plastic wd machine
    ull need to order all the bits seperate for that
    #261738
    timdowning
    Re: BWD129
    Cheers.
    Oh by the way;
    pcb’s that can only be programmed by the manufacturer
    Can you not buy the new hoover pcbs pre-programmed anymore??
    #261739
    helo_75
    nope
    #261740
    helo_75
    well, u can for the older ones, while stocks last
    unless of course your prepared to buy an emit programmer, and they ain cheap
