Re: (Bypass)bosch fridge freezer thermistor
I think that this is what you want:
sparkey wrote:Machineman,
First identify the sensor leads on the module, usually either a three pin or a four pin connector.
If four pin, locate the twin cable connected to terminal 1 & 3 cut off sensor cable about 2in from module and join together effectivly shorting out terminals 1 & 3 on the module connector.
If three pin locate sensor lead connected to terminals 1 & 2 and do as above. TAKE CARE to not disturb the other sensor lead which is also connected to terminal 1.
Terminal numbers are moulded into the white moulding of the connector plug.
Regards
Sparkey
