Cable WDI1210 not releasing water after cycle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Cable WDI1210 not releasing water after cycle
  • #53145
    bones020
    I have a Cable Washer Dryer WDI 1210 and this fails to release the water after a cycle wash. Is this a known problem with this model or is there any way I can get this repaired?
    Thanks in advance, can anyone help 🙁
    #314575
    Re: Cable WDI1210 not releasing water after cycle
    Caple….
    The filter behind the kick board at the bottom will be blocked. Drain the machine manually and unscrew the filter – check right back into the pump chamber with a torch.
