Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Campini Ty60
- This topic has 14 replies, 4 voices, and was last updated 14 years, 11 months ago by
iain_neilson.
May 10, 2011 at 5:24 pm #62704
iain_neilson
ParticipantI am looking for the following part:
Campini Ty60
10/250~
16/250~
T210and….
47-99
140 Degrees CI note someone found one of these for £1.62, although it was a few years back. How much are they now???
May 10, 2011 at 6:03 pm #351015kwatt
KeymasterRe: Campini Ty60
What is it? What’s it from?
May 10, 2011 at 9:57 pm #351016iain_neilson
ParticipantRe: Campini Ty60
It is a thermostat from an oven.
I have found the manufacturer’s website (http://www.campinicorel.it/cmsCampini/P … _en-9.html), to check that they still make it, but have not found a UK distributor.
Any ideas?
May 10, 2011 at 10:03 pm #351017kwatt
Yes. 😉
Give me the model number, make and anything else off the rating plate of the oven that you have.
More often than not the manufacturer of the part’s information is utterly useless to us as everything in this industry is part number driven. No part number, can’t do a thing with it. Can’t look it up, couldn’t tell you if it was a thermostat, a motor or a box of frogs.
We get the part number from a process of make>model>(serial/PNC/Index)>part number.
There is rarely an exception to this method.
Sorry for being blunt, but without the relevant information no-one will be able to help you.
May 10, 2011 at 10:12 pm #351018kwatt
I just had a look at that page in more detail from Campini.
There’s one very vital bit of information missing from it… what temperature the stat is preset to or, what range it’s to read.
In an oven I’d expect it to be used as a cycling stat or a temperature overheat cutout. In either event, it will be preset for the particular application to a temperature as the information there is generic for a multitude of different applications. Each application will have a production run specific to that application.
Hence the requirement for the part number or you could just end up with a random temperature that may well not work as you need it to. 😉
May 10, 2011 at 10:14 pm #351019iain_neilson
Thanks for getting back to me so quickly. It is a SMEG A1 Opera cooker, but I don’t have the other details to hand.
I’ll have to look it up tomorrow, as my wife has already gone to bed.
May 10, 2011 at 10:32 pm #351020iain_neilson
I think this is the right part number: 818730566, which is available from SMEG UK.
Without the right part number, it is difficult to be sure…
May 10, 2011 at 10:50 pm #351021kwatt
If you remind me tomorrow (I will forget ;)) I’ll post up a parts blowout if I can dig one up, which I should have in the office for an A1.
I’ll be able to track it down for you and may be able to offer alternatives from the Smeg one, maybe as some Smeg prices are just stupid.
May 11, 2011 at 7:53 pm #351022iain_neilson
OK: here is the info on the rating plate:
SMEG A2 Type 2DA N 090 05795The thermostat is set for 140 Degrees C, range 47-99
May 11, 2011 at 8:09 pm #351023kwatt
KeymasterMay 11, 2011 at 8:26 pm #351024iain_neilson
Thanks, K
I will order that.
November 18, 2015 at 4:58 pm #351025rtottley
I’m also looking for the same:
Campini Ty60
10/250~
16/250~
T210but for the ATAG OX911M
Any ideas where to find this part in the UK?
November 18, 2015 at 5:03 pm #351026rtottley
Also states temp on the thermostat of 170C
November 18, 2015 at 5:18 pm #351027kwatt
No parts show as available for that model I’m afraid. 🙁
September 19, 2016 at 5:17 pm #351028Flapajack
iain_neilson wrote:
SMEG A2 Type 2DA N 090 05795I have a Smeg with almost identical ID, the only difference being the last 5 digits – so SMEG A2 Type 2DA N 090 05732.
What exactly is the correct designation for this model when I am looking for spare parts? Apparently A2-2DA doesn’t exist and there are lots of different variants of the model A2.
Can anyone shed any light on this? I am looking for a replacement oven fan motor but is struggling to identify the correct one.
TIA
