Can any one help ????????
  • #48415
    BEKOBOY
    need to know how to go into diagnostics for the following machine……
    HOTPOINT WF541
    #296540
    helo_75
    there isnt a diagnostic test without a hardware key.. what problem have you got?
    #296541
    BEKOBOY
    Re: Can any one help ????????
    On programme 5, takes water for 20 sec, motor action then stops.[on/off flashing rapidly plus rinse hold and mini load flashing.
    #296542
    helo_75
    ok
    thats a fault code
    if you count the neons, top to bottom (1-5)
    WHICH ONES ARE FLASHING? i.e 1 and 4 / 2 an 3 etc
    all on the known error codes
    http://www.ukwhitegoods.co.uk/downloads … 0codes.pdf
    good luck
    #296543
    BEKOBOY
    Thanks very much for for all your help, if you ever need info on BEKO ELECTROLUX B/S/H GAGGANU MIELE appliances let me know and i will help you out.
    Thans again
    #296544
    helo_75
    thats ok mate… just remember, thats what were here for.. theres a wealth of multibrand info here, all you need to do is ask
