Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Can anyone help me with my Belling dishwasher?
- This topic has 5 replies, 2 voices, and was last updated 10 years ago by
georgianna:).
April 1, 2016 at 11:45 pm #87999
georgianna:)
ParticipantHello, I am new to the forum. I have moved into a house with a fitted Belling IDW604 dishwasher. It worked three times then stopped. I could no longer select a program. After searching the internet, the advice was the door latch was probably stuck.
I pulled the latch back into position and the program selector worked again and the door shut properly.
I thought I had solved the problem! But unfortunately not, the machine did not start to work and instead just beeped about every 30 seconds repeatedly… I have searched the net again but as the machine shows no error codes, I am at a loss. Thank you for any advice you can give me. 🙂April 2, 2016 at 1:44 pm #436706Seamy
ParticipantRe: Can anyone help me with my Belling dishwasher?
do the beeps come in any order, for instance are there perhaps 3 beeps, 4 beeps then a pause, the number of beeps normally give an indication to error
April 2, 2016 at 2:47 pm #436707georgianna:)
Hello Seamy, after setting the program and closing the door, the first beep is after 53 seconds, it is just one beep, then it repeats this one beep every 53 seconds after this. I timed it for over 5 minutes. Then I switched it off. I hope this information is of some help. 🙂 Thank you
April 4, 2016 at 7:42 pm #436708georgianna:)
Hi thank you for reading this. I watched a video on changing the door catch. So I unscrewed the door of the machine just enough to see the door catch (as in the video there were a lot less wires/pipes etc in the machine than in mine!).
I can see that the bit that the metal loop fits into is facing the wrong way (towards the front of the machine instead of towards the inside of the machine).
So my question is should I remove the catch try to mend it or buy a new catch, if so where do you recommend? Also I am an absolute novice and the sight of the insides worried me a little. Is there anything I should or shouldn’t do? Thank you so much for your help 🙂
April 5, 2016 at 7:30 am #436709Seamy
Hi Georgina.
Perhaps if the inside of it scares you & you are neither confident or perhaps competent to do a repair, you would be best advised to call a repair engineer?April 11, 2016 at 10:40 pm #436710georgianna:)
I have solved the problem, I bought a new door catch and I fitted it. My dishwasher works again! 🙂 Thank you all. Georgianna
