Re: Can anyone help? Smeg DW1612C dishwasher broken.
tinalem1 wrote:Hello,
I’m not sure if a pcb timer is the same thing as a pcb.
Tina
Yes it is….in the days of yore, the control mechanism was basically an electric timer. These days electronics (Printed Circuit Boards) do the job instead but the name ‘timer’ has been in use for so long it’s still used quite often.
As to whether the machine is worth repairing, well that can be a subjective thing but even just financially you have to weigh up things like the cost of the repair, age of the machine, how much wear and tear it already has, the quality of the product and therefore it’s likely agespan, the ease of service etc, the cost of a replacement machine with the equivalent/cheaper/more expensive etc.
As you have found out, Smeg are not the cheapest to repair but against that they are not cheaply made compared to most IMO. They do suffer the odd breakdown now and again but then what machines don’t?
HTH?
