Can i just use it as a fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Can i just use it as a fridge
  • #76126
    waynesworld
    My Admiral f/f has finally given up the ghost after a number of repairs to the freezer , so we have ordered a new one , is there any way I can isolate the now defunct freezer part and use just the fridge on its own. Many thanx
    #397333
    Re: Can i just use it as a fridge
    No.
    waynesworld
    Thanx for the quick reply , can I ask why not . Thanx WW
    #397335
    The fridge draws cold air from the freezer, there’s only one refrigerant system for both.
    waynesworld
    Ah I see , is that why when my freezer wasn’t working properly the fridge seemed cooler
    #397337
    What has gone wrong with i before ? Whats the symptoms of the new fault ?
    Bryan
    #397338
    waynesworld
    Over the last few years there have been a number of problems had two new control boards fitted , numerous problems with the unit at the back of the freezer behind the panel(cant remember what it is called, looks like a radiator}freezing up, causing the alarm to go off , I have just been stripping the freezer down , defrosting it then it would work for a month or so , now just lasting a week , had various quotes for repairing , but to be honest just fed up with it
    #397339
    Then that’s a simple repair. a defrost heater.
    Would I choose between the majority of side by sides and repairing yours then yours would win hands down.
    Bryan
    #397340
    waynesworld
    Thanx for the reply , but in the 6 years we have had it , it has had at least one repair a year , which for what is supposed to be a high end F/F is not good, and currently that fault is there as is a clicking noise that no one can cure and the ice maker isn’t working , we just feel we are throwing money at it , the fault was actually diagnosed as a circuit board by a local engineer, so as my OP I was wanting to keep it in the garage as a fridge , well actually an wine cooler , but I understand this is not possible. Thanx WW
