Candy 100t W/M
  • #15332
    maltheviking
    I thought I had these beggers “bossed” but I have had one today that I could have kicked out the window.
    Went to it last week, fault from customer;– timer sticking on spin, two or three turns in distribution then dead. I tested it and ran it for one hour. no problems!!.
    Had to return today for same fault, customer had left it in the fault position. I switched it on, full spin!! switched it off then on, fault occured. all components checked out ok, swaped module, fault still there.
    My money in on the selector switch, but I did not have one to try it out.
    Anyone come across this one ?
    #163136
    maltheviking
    Re: Candy 100t W/M
    Update. May be of use.
    My suspicions were correct, the timer/selector switch was faulty. Stripped it down but could not see any problems, gears all ok. sync.motor OK
    #163137
    Re: Candy 100t W/M
    I think it’s that the carbon tracks get worn and carbon gets spread across the intervals so the slider contacts make intermittently when they shouldn’t. Cleaned up a Hoover one recently and it hasn’t come back yet.
    (Only did it because got sent the wrong new part 😉 ).
    Mike
    #163138
    maltheviking
    Re: Candy 100t W/M
    leavemetogetonwithit wrote:I think it’s that the carbon tracks get worn and carbon gets spread across the intervals so the slider contacts make intermittently when they shouldn’t.
    Carbon Mike?, this one had gold plated tracks, but yes they were a bit “grubby”
    #163139
    Re: Candy 100t W/M
    I must be getting old. I thought I remembered seeing carbon tracks in there. Maybe it was just dust but I’m pretty sure it was that which was causing the problem. (Touch wood).
    Mike.
    #163140
    maltheviking
    Re: Candy 100t W/M
    Just when you thought it was safe to go out again!!! 🙁 egg on bl**dy face
    Customer just rang, machine did three washes ok, then gone back to original fault. Back to the drawing board.
    😥 Got a headache coming on, need a pill to chill!!!!! 😥
    #163141
    Re: Candy 100t W/M
    Dodgy Tacho Coil I would think?
    #163142
    Re: Candy 100t W/M
    Or p’raps just the contact to it at the motor plug? Especially if it’s one of those insulation displacement terminal type things.
    Mike.
    #163143
    maltheviking
    Re: Candy 100t W/M
    Did most of these checks first time, tacho, wiring loom. Tested the motor at its terminals and at the other end of the loom.
    #163144
    Re: Candy 100t W/M
    In the old days, before all the health and safety stuff and threats of regulation etc., a man would have been free to poke all possible loose connection areas with a long wooden stick to see if anything suddenly jumped into life. 😉
    Mike.
    #163145
    maltheviking
    Re: Candy 100t W/M
    Or equally as good, a plastic Biro. Although I might get round to a rubber sledge hammer
    #163146
    Re: Candy 100t W/M
    maltheviking wrote:a rubber sledge hammer
    I thought you would use one of those funny shaped axes.
    Mike
    #163147
    maltheviking
    Re: Candy 100t W/M
    You must mean the”battle axe”, unfortnatly she is not well insulated and besides who would make my tea? 😆
