Candy 266A, Run continually
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Candy 266A, Run continually
  • #28412
    simrjor
    Had this about 7 months, over last week had control unit and temp sensor replaced. But the unit seems to run continually. Thermostat set on 2.
    The freeze compartment is icing up. From what i’ve read it could be air getting in as the top left had a thin fluffy ice from left to center, but the seals look ok.
    Any idea, what rights do I have about replacement or return?
    #218264
    Dales-Electronic
    Re: Candy 266A
    From what you say you are still under guarantee – get them back to sort it out
    #218265
    Re: Candy 266A
    Have you tried turning the stat down? Most Candy and Kelvinator fridge freezers always needed to be set at about 1 or below on the old thermostats.
    simrjor
    Re: Candy 266A
    kwatt wrote:Have you tried turning the stat down? Most Candy and Kelvinator fridge freezers always needed to be set at about 1 or below on the old thermostats.
    When the last engineer came he said 2 was the lowest I should go, so the fridge would be could enough!
    #218267
    simrjor
    Re: Candy 266A
    Dales-Electronic wrote:From what you say you are still under guarantee – get them back to sort it out
    They’ve been twice! What else can they change? It’s not very convenient to have them keep coming back!
    Can I ask them to replace it or take it back?
    #218268
    Re: Candy 266A
    simrjor wrote:When the last engineer came he said 2 was the lowest I should go, so the fridge would be could enough!
    I’m not going to get into the specifics, but let’s just say that I’ve known that opinion to be incorrect.
    simrjor
    Re: Candy 266A
    Setting to one made no difference. The top left draw shown in picture is just getting worse!
    How many times to they have to come and do a repair before I can ask for a replacement or return?
