Candy Alise C10 washing machine leaking
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Candy Alise C10 washing machine leaking
  • #35794
    onegog
    I have noticed a pool of water in the middle, below machine. I looked underneath and noticed some drips in the middle below the drum. What could be a problem. Many thanks!
    #248120
    Anything really in all honesty, you’d have to try to see where the water is coming from as it will always fall to the lowest point because of gravity.
    Sorry, not a lot of help other than try to track the leak.
    onegog
    Re: Candy Alise C10 washing machine leaking
    Thanks for reply. To test if some of inlet hoses is leaking I filled the machine through the open door. It started leaking straight away. The outlet hose seems to be ok. Could it be the drum? Many thanks
    #248122
    It could be the drum yes, or just about any one of a dozen other things as well onegog, you really have to trace it back and see if you can see where the leak is, there’s no easier way I’m afraid.
    If you’re not comfortable with trying to track it I’d suggest you get an engineer to look at it.
    HTH
