I have a Candy AQ110 that when set to spin, drains ok, distributes ok then after approx 2 minutes just stops, and does nothing the mains indicator is still lit up but no life from the machine. If you switch the machine off and back on again it runs again for approx 2 minutes then stops again. I have tried the following :- change module, change timer, change pressure switch, change thermistor, motor, pump, on/off switch, heater and because I was getting desperate the mains filter. all parts were taken from an identical machine that I had in the work shop, was working but knackered bearings. Any ideas???
