Re: Candy Aquaviva 1300
Teedee wrote: but then sticks and will only work if I manually click onto the next cycle.
Probably not heating the water up then? When it sticks does it just sit there on the main wash cycle? I’m sure that’s the case 😉
I’m reckon that when you advance it past the heating part of the cycle (say) onto a rinse and spin? It works OK then doesn’t it?
New heater required if I’ve guessed right so far. 🙂
See the link below for an equally friendly engineer to sort it for you (and it’s not a costly job either…(in case that was your next question? 😉 )
