Candy AT130
  • #37490
    Don’t do a lot of Candy, not seen this one before.
    Complaint of over heating.
    NTC reads 33kΏ when cold, using the boiling cup of water test it is operating normally.
    No breaks in wiring.
    Set machine to long spin to check on slave timer operation. It moved from SPIN to OFF then clicked on once more to programme 5, the next one on the dial from OFF then stopped.
    Fault has been intermittant. :rolls:
    Any previous on these machines?
    timdowning
    Re: Candy AT130
    The normal 91201337 selector on this one so always a high chance the selector is at fault.
    Are you sure no-one else has had the selector knob and cam off and put them back slightly out of synch? (This is possible.)
    If all of the above ok then it can only be the module.
    #255290
    Re: Candy AT130
    AFAIK the machine is untouched, old lady on her own, first fault on machine.
    Possibly worth trying a timer.
    EDIT. Just checking through my box of ‘Parts ordered over the years and not used’ 😉
    I have one of those timers, this one is a white Invensys job,I’m sure the one in the machine was a black one with a much larger motor, are they interchangable?
    timdowning
    Re: Candy AT130
    I would have thought the one in the machine would be the same as the one you have in stock. The part number should be on the selector in the machine. (white sticky label).
    #255292
    Re: Candy AT130
    it is listed for this machine, perhaps it has been superceded.
    Will give it a whirl.
    Thanks. 🙂
    Madmac
    Re: Candy AT130
    We’ll all wait for the huge bang ! 😉 :mrgreen:
    #255294
    Re: Candy AT130
    I wont be spraying it if thats what you mean. 😆
    jim.
    #255295
    Madmac
    Re: Candy AT130
    Using a solvent switch cleaner on a timer is only a good idea i have found Jim, if one leaves a reasonable time for the product to evaporate before testing.. 😯 😯 😆
    #255296
    Re: Candy AT130
    Don’t you just love it when you go to a machine and they say, ” it wasn’t moving on so I sprayed all the controls with WD 40, now it wont do anything” :rolls: 😆
    Madmac
    Re: Candy AT130
    Reminds me of an old geezer that i used to go to for many years who proudly told me how he doused the timer on his old 800 Electron ‘at least twice a year’ with WD 😯 Hav’nt heard from him in a long time.. 😥
    #255298
    Re: Candy AT130
    Invensys timer was a direct replacement for the Chinese tat fitted originally. 8)
