Sounds very similar to the problem congoblue was having was having with his Neff but I’m having with a Candy c4400. Seems nice and hot when washing and rinsing but everything seems very wet at end of drying cycle! I wonder if the experts could tell me if there is a pressure chamber to look for (full of gunge?)or is there some other cause? many thanks
There is a pressure chamber at the front of the machine, underneath, retained by 3 screws. Pull the cover and clean inside thoroughly. Power off first.
Poor drying with heat is often caused by lack of rinse-aid – the stuff in the multifunction tablets rarely does what it says on the tin.
Thanks Penguin45, I’ll have a look. The door works a treat now. We use powder and rinse aid but at the age of the machine I bet it does have some gunge! Is the pressure chamber underneath at the front or behind the small panel below the the door?
Thanks Penguin45, got a whole load of muck out and drying seems much better! Lady Greentreeman is most pleased! Keep up the good work on this great forum. 😆
