Candy CBE165T
  • #30076
    nikki1966
    Washing is not filling though there is a clicking noise as if it is trying, also last night it filled but didn’t wash or spin. Am desperate as have holiday washing to do and two small boys.
    #225789
    Re: Candy CBE165T
    Has the door actually locked?
    nikki1966
    Re: Candy CBE165T
    Door is locked, fills with water, completes cycle but drum doesn’t rotate although it sounds as though it is trying to move. Machine also empties at the end of cycle.
    #225791
    Re: Candy CBE165T
    Better have a read of this then:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=156
    Power off, if you are going to investigate.
    nikki1966
    Re: Candy CBE165T
    Thanks for that, but am I supposed to look through the top, back or bottom of the machine as I have looked in the back and top and can not see anything. Sorry to be so useless.
    #225793
    Re: Candy CBE165T
    Drive motor is under the drum – easiest course of action is to remove rear panel and undo two bolts – motor can be pulled off it’s lug for inspection.
    nikki1966
    Re: Candy CBE165T
    I have found the carbons and clean them, what are the chances of the machine working now. Also how easy are the carbons to fit. do they need soldering?
    #225795
    nikki1966
    Re: Candy CBE165T
    The carbons didn’t look worn down or damaged to me. Can you sugest anything else?
    #225796
    Re: Candy CBE165T
    If you are certain that the brushes are not finished (a good centimetre in length at least), there is little else apart from some sort of wiring problem (unlikely) or the computer board itself. As this is an expensive component, it’s probably time for professional help to confirm the diagnosis.
