candy CD622 not washing properly
Home Forums Public Support Forums Help And Support Dishwasher Help Forum candy CD622 not washing properly
  • #79446
    missmouse
    Hi, our Candy CD622 is not washing properly. It no longer makes the same sound of water spraying about as powerfully as before. I have checked the spray arms, filter & even had a look underneath at the motor for signs of burning etc. The motor does seem to be covered in a fine white dust which I think is from the built in fan rubbing slightly on another part. Can these motors still work but lose power?
    We dont want to buy a new motor at £100 or so unless Im sure that is the problem! Oh, & there is also a burning smell while it is running although as I say, there is no obvious signs of burning to any of the components under the machine!
    thanks in advance!
    #409290
    Andy jones
    Re: candy CD622 not washing properly
    Does sound like a wash pump
    Fault tbh.
    #409291
    missmouse
    how certain are you tho? Im guessing it cant really be anything else but I would have thought the motor would either run or not run?
    #409292
    Andy jones
    Well I can’t be certain having not seen it but if you checked spray arms etc there not much left. How much water is getting into the dishwasher
    #409293
    missmouse
    plenty water getting in & its heating up fine & pumping out again ok. It seems to run thru its cycle same a s before just not washing as well!
    Have you ever heard of these pumps losing power but still running?
    Ive not removed it to check the impeller but if that is worn then Id guess it would be best to replace complete pump unit anyway?
    I think its about 10 years old now so thats why we dont really want to splash ( ha ha) out £100 for a pump on off chance!
    Im sure we can buy a complete new machine for not much more than double that?
    #409294
    Andy jones
    They can wear out. Replaced
    One on an indesit only last week for the same symptoms
    #409295
    missmouse
    ok, cheers for the advice! Can you point me to a decent replacement? Ive seen a few online but also read the cheapies dont last.
