Candy CDB126-80 drum bearings
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Candy CDB126-80 drum bearings
  • #102463
    sexton_mallard
    Hi all,
    I’m looking for replacement drum bearings and seal for a Candy CDB126-80. I don’t seem to find them listed on all the usual parts sites. Can someone confirm if the set listed on the following link would be suitable? Thanks in advance. The link is: https://shop.ukwhitegoods.co.uk/cy05102-washing-machine-bearing-kit
    #488954
    ok first let me have the long serial number off the label
    sexton_mallard
    Hi Dave, thanks for responding so quickly. The S/N is 31800064 0920 1381
    Type LCE2
    RPM 1200.
    #488956
    ok what I get is
    92445600 seal
    92440171 6205
    92440197 6204
    bearing can be got from a bearing supplier locally and order seal seperatly
    or
    kit looks correct for your machine
    sexton_mallard
    Thanks Dave! I’ll shall investigate and update on progress.
    #488958
    sexton_mallard
    The bearing set was received and installed with success :). The old bearings took a lot of hammering to get out of the carrier/hub. The replacements went in with more ease after a 20 minute chill in the freezer. Disassembly was done with the door seal removed then the front weight, motor, pump, dryer blower and discharge pump to avoid any damage. The machine benefitted from a clean out of all the interior including the dryer heater and dryer ducting.
    This was hard graft but very satisfying. I was surprised how little deterioration there was internally. I’m quite impressed with this machine which is on its 2nd set of motor brushes. It was manufactured in 2009 as NOS and used from 2011 to the present day and provides washing for a family of 3 with a large dog. The dryer is hardly used but will be used occasionally to keep the machine in good order as before.
