Candy CDC266 Dryer
  • #48895
    jackster
    I have got this dryer that customer says is not drying. It gets warm but never hot enough, the condenser is clear as are channels etc. I am unfamilliar with these machines so a little help needed. Thanks in advance.
    #298109
    jackster
    Re: Candy CDC266 Dryer
    Further to the above post, I have noticed that the filter light keeps coming on, only briefly but it comes on every 20 secs or so. I have cleaned the filter and sensor and the mc is now heating to around 60 deg. Not sure if the sensor is faulty, would this effect filter light keep coming on?
    #298110
    when filter light comes on normally the sensor stats on the element
    sounds like element will need replacing soon cant buy stats on their own
    jackster
    Sounds about right!
    Cheers Dave
    #298112
    jackster
    Ok you Hoover/Candy engineers or any engineers I need help! I have replaced the heater and the exhaust/filter housing stat and still it only gets to 30-35 degrees before cutting out and the filter care light comes on, it will then gooff and heater comes on for a few seconds before cutting out again.
    I have checked all connections to timer, heater, stats etc but no joy.
    Could it be the timer ya think???
    #298113
    jackster
    Can anyone help me out on this one 🙁
    #298114
    my first question is how do you know the heater is only on for a few sec ?
    from what i can read you have replaced everything exept the timer
    if all covers are on then it has to be an airflow problem assume you have checked condensor etc
    run it with the door open for 5 mins and see what happens when air is not recirculated
    hope this helps
